Ok, I know that this is probably something I am going to need a TBC for, but I am trying to figure out anything else that will work to fix this problem. Basically when I capture anything from a VHS the top of the screen is glitchy and white and there will be blips occassionally.
I have a JVC HR-A34U model VCR. I am running this to my computer via composite inputs. I am pretty sure that it does not have a SVHS output.
I have an ATI All-in-Wonder 9700 capture card and I am capturing with the ATI TV program.
Is there anything I can try to maybe solve this without a TBC?
Thanks guys,
BJ
Sounds like overscan. It is caused by your capture card picking up the entire video image, even the part caused by the rotating head on your VCR. You don't see it normally because VCRs are designed not to display the portion on your TV, but your capture card is showing it to you. If you go ahead and convert it to DVD, it won't show on your TV, if you want to view it only on your computer, programs like VDub with its Null filter can crop it off.
Here are some examples:
http://msit.bloomu.edu/wkaledas/images/example1.jpg
http://msit.bloomu.edu/wkaledas/images/example2.jpg
http://msit.bloomu.edu/wkaledas/images/example3.jpg
http://msit.bloomu.edu/wkaledas/images/example4.jpg
http://msit.bloomu.edu/wkaledas/images/example5.jpg
I think you may be partly right, but you can see that the image behind is showing through.
In example 4 and 5 you can see frames next to each other where one you can see the top and the next is white. -
It also looks like poor tracking, or bad quality tape. Are all your tapes like this?
Ahhhhhh....My favotite video subject, False MV and the ATI card.
Originally Posted by Kunta Kinte
There's more here: www.nepadigital.com/mv
Sorry Uppitycracker besides a TBC and possibly other devices such as some of the Sima products AFAIK there's no solution.
I sent you a PM make sure you read it. -
Hmm, after some tinkering I turned off the "Video Stabilizer" function and this seems to have fixed the problem.
Let me try more tapes and let you know. -
Originally Posted by uppitycracker2
BTW...... Go Eagles.
Best method for capturing VHS?
By blud in forum Newbie / General discussionsReplies: 7Last Post: 6th Apr 2012, 04:06 -
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 08:37 -
capturing vhs to hdd
By zulubase in forum Capturing and VCRReplies: 2Last Post: 20th Feb 2010, 17:00 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 16:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 09:32
