Hi,
I apologize for the double post. I think I had the other one in the wrong topic and I am not sure how to fix it.
I got this ati recording thing. I just love it the picture and audio part is very good. Anyway I recorded my frist movie with the studio 9 software which is what it came with. I went to edit it with the studio software and when cutting out the commercials, some of the scenes still had commercials in them. Then I subdivided the scene to the least amount it would allow and even with that some of the commercial is still there.
How would I be able to cut all of the commercials with studio software because what I tried did not work or is there other software that works for doing that instead? Please and thank you.
Hi,
Try VideoRedo OR
The free app Cuttermaran,I find this very good for cutting unwanted stuff. -
With Studio 9 you can try this:
1. Be sure that you capture with the scene splitter function on. or get the program to do the secene detection and splitting upon reload.
2. Drag the whole captured movie from the album down on to the timeline.
3. Cut out the comercials by right clicking and selecting delete. If you look for black frames you can usually find the beginning and end of comercials.
4. Export the project to an avi or whatever you want. The comercials will still be in the original capture file, but the exported project should be cleaned up.
Please excuse me if this is not what you wanted to do. -
Hi,
Thanks for telling me about the software canadateck. I will try it does that work better to cut out?
Thanks for telling me about george_alass different ways for studio 9. I was able to split the scenes, however, there is still some comerical at the end of the scene and it will not split any lower then 1 that I am able to see and 1 is still not low enough?
Deleting files and directories
By Jomapil in forum ComputerReplies: 11Last Post: 20th Mar 2012, 05:41 -
Deleting cookies?
By neworldman in forum ComputerReplies: 3Last Post: 21st Jun 2011, 12:52 -
Deleting subtitles from videos
By angeloslev in forum Video ConversionReplies: 1Last Post: 23rd Feb 2011, 21:33 -
Deleting Audio Tracks
By cmars in forum AudioReplies: 2Last Post: 28th Apr 2010, 09:00 -
Deleting Extras with BD Rebuilder
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 27th Dec 2009, 23:10
