Hey. I've got a question regarding using ffmpegx and DVD Studio Pro 3 together. I'm relatively new to DVD SP but I've tried importing "assets" or files into DVD SP, but it doesn't seem to be working right. I use ffmpegx to create the .m2v and .ac3 files so that I can then import them into DVD SP but when I tried that, it still didn't work. There are only certain types of files that are DVD compliant with SP, so how do I make sure that the encoded files are as DVD compliant as possible? Nothing seems to work. I can't import avi/XVID files directly into the DVD SP program, nor can I VIDEO_TS folders, mpg movies, etc. I have the same problem with iDVD. Neither of the two programs recognize or let me import any sort of quicktime video files.
What is the correct way to do this?
Ok. I'll try that. Thanks, major. I'll keep you updated and if I have other issues, I'll let you know.
I used ffmpegx DVD which might have been the problem. With regards to the 3:2 pulldown menu...some of the files I use are XVIDs encoded in PAL, but I have simply converted them to NTSC with DVD ffmpegx. So, I should encode with mpeg2enc, add a 3:2 pulldown menu to the resulting m2v file, then import it and its corresponding ac3 file into DVD SP?
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 21:06 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Vegas Movie Studio 9 Platinum Pro Pack question
By dbanimal in forum EditingReplies: 8Last Post: 8th Jan 2010, 11:13 -
DVD Studio Pro
By macuser1960 in forum MacReplies: 3Last Post: 12th Mar 2009, 08:45 -
Pinnacle Studio HD DVD authoring
By spacejamz in forum Authoring (DVD)Replies: 3Last Post: 19th Sep 2007, 14:42
