  1. How do I brighten a movie using TMPGEnc? Also, how do I get rid of the black blotches in the VCD's I'm making?
  2. Banned
    Jun 2001
    UK
    Before you hit the start button, hit the settings (Bottom right) then select the advanced tab.
    From there you can change a lot of things like brightness etc
  3. To increase brightness also try cranking up the GAMMA found by clicking on Settings, advanced tab, then DOUBLE click on color correction.
