Hey all, Im a newbie... My big problem with converting dvds once i rip them is that i can never get them to fit on a 700 meg cd. I've used the bitrate calculators to determine the proper bitrate, I've used virtual dub to put the audio and video together and I've looked at 3 billion different ripping packages with directions. Everytime I convert to either an mpeg or an avi, the file size comes out to be 800-900 meg. I cant stand it. Is there any prog out there that allows you to shrink the size to 700 meg or less? any advice would be sweet. thanx
When you used the bitrate calculator did you have it set to DivX for xVCD/SVCD? An 80min CDR will hold 700MB of mode1 (DivX) data or 800MB of mode2 (MPEG) data. That 'could be' the problem?
The bitrate calculators should work so...
Convert DVD to ca 700 MB avi using what?
By younso in forum DVD RippingReplies: 2Last Post: 9th Feb 2011, 18:57 -
Ripping a DVD to H.264 + AAC within 700 MB
By moiz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Oct 2008, 22:45 -
Would there be quality loss if 2 avi files of 700 mb made into one DVD
By meurglys0 in forum Authoring (DVD)Replies: 8Last Post: 11th Apr 2008, 21:57 -
Burn in subtitle in a AVI div-x film
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2007, 11:02 -
a 700 mb movie burned in 1 cd would it play on DVD players
By ianskiee in forum Newbie / General discussionsReplies: 5Last Post: 10th Jul 2007, 13:05
