I installed the codec and it does not appear as one of the rendering options in Vegas.
I loaded Video Codec Swapper and I see the codec listed there, so it did install properly.
Uninstall, then reinstall VEGAS,
, and PUT THE CODEC back in in the INTERIM.
this usually does it.
Which XVID CODEC version did you choose?
this may also affect the outcome
XviD 1.1.0-beta2 release. or
Koepi's XviD Codec v1.0.3 ? -
It turns out that it is accessed through the Video for Windows option. It's working now.
I understand..you didn't know where to look for installed codecs!
by the way, they always do this in applications (UNDER .AVI) because WINDOWS direct x has classified all MPEG-4 as WRAPPED in an AVI header..
pretty f**cking confusing, but if you think it was a political bias against open source codecs, youre wrong
cause the confusion between liscensed MPG1 and MPG 2
is equally hidden in their idioctic choices to lump all together in the same file ending!
Codec won't work with Vegas
By Jon.G in forum EditingReplies: 1Last Post: 26th Sep 2011, 07:52 -
Vegas : best codec for editing?
By grendizer in forum EditingReplies: 6Last Post: 18th Aug 2010, 06:20 -
Best AVCHD codec that will work with Vegas?
By The111 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Nov 2009, 21:54 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 17:13 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
