i used AVI codec on a mpg i extracted from a svcd and it showed as MPG2 (SVCD DVD)
but a mpg from SVCD is not same as DVD?
dunno little bit confused.
if i joined 2 of these authored them and burned them, i'm led to believe it would not work on standalone that does not play SVCDs.
so why does it show as (SVCD DVD)?
Results 1 to 9 of 9
SVCD and DVD uses different resolutions. SVCD is 480x480. This format is not a correct DVD format.
http://www.svcd2dvd.com/Guides/GettingStarted%5FSVCD2DVDv2/
Info on both are to the left under What is. -
You can however take an mpg from a SVCD and author it as DVD with some applications (DVD-Lab Pro) with a warning that it's not 100% DVD compatible. many (most) players will in fact have no problem with this.
/Mats -
READ!!!!!!!!!!!!!!!
https://www.videohelp.com/dvd
https://www.videohelp.com/svcd
Read about the audio!!!!!!!!!!!!!!!!!!!!!! -
is this right?
a DVD mpg and a SVCD mpg are both mpg2 but differ in resoulution and audio.
is there an app that tells u if a mpg is DVD compatible or SVCD?
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 10:17
