Is it possible to add chapters in AVI file so that it can act as DVD?
Results 1 to 12 of 12
No.Originally Posted by newnewsThere are 10 kinds of people in this world. Those that understand binary...
That said .divx which is an extension/hack of the avi container does support chapters. Also menus, subtitles and other DVD like features.
...and what players (hardware) support this "standard"?
/Mats -
Any DivX certified one.
At least via a firmware update. All current certified ones should at least currently support XSubs and multiple audio streams.
Not saying I agree with this whole DivX standards thing. Personally I would prefer players that support mp4 as a container complete with menus and full ASP video support. But the fact is that DivX certification is here to stay and so I guess is their hacked avi container or at least avi. -
The Vidomi extensions to the AVI spec include Chapters, Subs, and a few other things. So, obviously you could use the vidomi player, as well as others that suppport this.
Anyway, you can ALWAYS use an ASX metafile (Google ASX and METAFILE, or search my past posts), which is a text file that points to your AVI/MPEG media and also allows for chaptering, hotlinks, etc.
Scott -
Thanks for reply. So the answer is yes. then what tools is able to so that? I have some AVI movies(DivX) and would like to try it. Is VirtualDub able to do?
No, the answer is still No. Not in an AVI.
..divx which is an extension/hack of the avi container does support chapters
/Mats -
A little bit confused. Does DivX compressed AVI movie equal to .divx? If not, how to convert AVI to .divx?
".DIVX" is an AVI file renamed with "DIVX" as the extension. FILE.AVI -> FILE.DIVX
AVI is a container -- a box you put stuff in. Usually audio and video. The standard was designed in a way that makes it possible for AVI files to contain other types of data. Anybody can add data to an AVI file as long as they stay within the defined rules. But that doesn't mean anybody else has any idea what that additional data is. If a company defines new types of data, usually only that company' player supports those features. Other companies' products simply ignore the additions.
Divx (the company) has added features to AVI files -- and to differentiate files with those extra features they've renamed them DIVX instead of AVI.
Divx certification only guarantees that a player can handle DIVX compressed video, and a few types (MPEG and PCM?) of audio. I think there's also a requirement that the firmware be updatable to fix bugs and support new features -- but that doesn't mean a company will provide updates to support the features you want. -
Actually I think there are different levels of divx certification eg home theatre handheld PDA and I expect they will include chaptering (+ menus, somwhere) soon.
all divx are AVI files, not all avi files use divx..
Avi is a Jar that contains water, Not *all* jars contain water...
Avi is a sandwich .. sandwiches have many fillings
I think that's part of Divx 6 which was recently (a few months ago) announced.Originally Posted by RabidDog
Best way to add pop-up chapter menu?
By mikeveli20 in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2011, 01:08 -
add new title to existing DVD while keeping chapter marks
By brennbaer in forum Authoring (DVD)Replies: 8Last Post: 30th Jun 2009, 05:28 -
add all chapter in a DVD to one file
By Cazz in forum DVD RippingReplies: 4Last Post: 27th Jul 2008, 18:10 -
question about how to add chapter points to already made DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 24th Apr 2008, 15:44 -
Want to add chapter breaks to a video. Suggestions please.
By Super Warrior in forum EditingReplies: 3Last Post: 27th May 2007, 14:56
