Have an IBM thinkpad with XP home edition, which has on button and on rare occasions when it crashes ctrl+alt+del works.
Today it crashed badly-with a message that windows was switched off to avoid damage to my laptop.
Nothing worked-looked for power button-none-finally thought of removing battery and turned it upside down -it switched off!!
Any better way?!![]()
Results 1 to 9 of 9
Hold the power button down for 5 seconds and the machine will power off.
On occations, I've found removing the battery to be the only way out, yes.
/Mats -
Which Thinkpad model? There should be a reset switch near the power button. You'll need a paper clip or pen point to press the switch since it is recessed in a small hole.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Glad to know,i'm not the only one who has faced the problem.
Could not find reset switch of any kind
Think held down power button for some time, not sure-will try next time.
The alarm was on loud,could not turn it off,volume buttons were not working, was desperate.
Foryunately, no damage to laptop-still working OK
We had this DIGITAL laptop at work (top of the line when it was new), that had a port replicator attachment that fitted to the bottom of it. You could only get the attachment off when the machine was powered down. Naturally the attachment covered the battery bay.
When the laptop crashed (and that was often) you could only power it down by yanking the battery, but if the replicator attachment was on you were screwed and just had to let the battry drain!!!!!! -
Located my manual.
It says to hold the power button down for four seconds
If that fails, to remove battery!!
Guess that means I have to move around with a laptop and a screwdriver
Cool - I had a Dell, that could start squealing like a pig, completely catatonic, with the only option left to remove the battery. Luckily, that was a simple operation. I see (and hear) before my inner vision this happening on the train, off to work, and having to wait for the battey to drain...Originally Posted by Snakebyte1
/Mats -
Perfect poetic description of the sound-drove me madOriginally Posted by mats.hogberg
Ripping 50gb Silly Question
By beric3236 in forum Blu-ray RippingReplies: 8Last Post: 16th Nov 2009, 20:30 -
Silly VideoLAN setup question
By Ensign in forum Software PlayingReplies: 5Last Post: 9th Dec 2008, 01:48 -
Silly mkv format, hd question.
By adkom in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2008, 05:36 -
Silly question about cable modem and PC
By cim in forum ComputerReplies: 15Last Post: 7th Jul 2007, 19:15 -
Silly Question About AnyDVD
By hech54 in forum DVD RippingReplies: 3Last Post: 10th May 2007, 02:29
