Hi guys,
I'm trying to record direct from my VCR, using the line-in as my audio input. I've connected it up however the sound levels seem to be too high, the audio bars max out if the line-in level is anything above mute. When i record however it *does* seem to sound alright although is very loud still for the volume the playback device is set to.
Any ideas?
Please try reducing the audio level from the source (VCR or whatever).
Let us know if it helps. -
You can buy a $5 "Attenuating Patch Cable" from Radio Shack which will lower the incoming signal. Still, are certain you're connected to line in and NOT mic in ?
Doesn't your capture card have an audio in jack?
Google is your Friend -
Hi,
I dont think its possible to reduce the audio out on my VCR. I've managed to record it and it sounds alright..just a bit louder than everything else on a set volume level.
And yep my capture card does have an audio in, but for some reason the capturing software i was using wouldn't pick it up.
best media player capable of high level h.264 video?
By hiohaa in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Mar 2012, 15:37 -
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 13:03 -
Ripbot Audio Level
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 20th Nov 2010, 13:03 -
How to level up High difference in speaking sound volume on video
By Ricardogn in forum AudioReplies: 6Last Post: 13th Sep 2009, 20:32 -
Looking for software that can improve too high level distortion
By jimdagys in forum AudioReplies: 6Last Post: 9th Jul 2009, 00:08
