i've been trying to figure a way to speed up my ripping of dvd's, smartripper and dvd decoder won't go any faster than 1.9x!!!!!!!!!! what can i do??????????? i have a toshiba 16x drive.
Results 1 to 28 of 28
If you hadn't said Toshiba, I would have tried to bust my head to help you out there, but Toshiba DVD drives are crap! plain and simple! if you get to 1.9x, feel honoured, i've seen a 16x/48x drive that barely reached 1.2x!
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Sadly, my Toshiba drive goes up to a max 1.6 (usually hovering around 1.2) so count your blessings...wink. One of these days I'll replace the bastard....
Macros -
I find speed is generally related to a) the DVD and b) decoding of the video. On my junky 12x DVD-ROM, I usually get about 1x - 4x on rented encoded DVD's, 4x - 6x on my home bought encoded DVD's, and roughly 8x on non-encoded DVD's.
I find that ~2x - 3x is about what I expect each rip.
- bewley
bewley's mp3PRO Rock
classic/metal/new rock streaming 24/7
Ziggy In Concert
david bowie unofficial discography -
Hi All,
Can anyone post several "excelent" DVD-ROM drives that will shorten our ripping time? I am getting 1.1x max.
Regards,
Jose -
I've had a Pioneer 10x/40x, and now I have a 16x/40x, and both drives were just about the same speed, ranging minimum rip time of 5x to 7x, and with the 16x drive I reach upto 14x sometimes.
Best Regards,
Sefy Levy,
I was wondering why my ripping was going to slow, now that I know.....what's a better DVD Drive than tobsiha???
Sefy,
Do you know how much CPU usage is involved in the decoding process and whether or not having a fast CPU would make a large difference in RIP speeds?
Thanks!
- bewley
Ziggy In Concert
epic47, get a Pioneer
bewley, i've had the same ripping performance on both my old Duron 700 and my current Athlon 1000, so if CPU has any boost, it's propably not by that much.
Best Regards,
Sefy Levy,
Make sure you have DMA on! I went from 1.3x to 5.2x just by setting dma.
-Smonkey
(an easy way to make sure it's on is to run a version of powerdvd) -
epic47....almost every DVD-Drive is better then Tosiba for DVD Ripping but a Tosiba for perfromance is okay but for ripping it just suk
Unfortunately, Smonkey, my Toshiba drive doesn't support DMA on....I don't know if others do. But it causes ALL KINDS of trouble if it is on.....sad really.
macros -
that why Tosiba SUK
_________________
<font size=-1>[ This Message was edited by: pinoy2201 on 2001-12-12 14:47:22 ]</font> -
I doubt many people who own will disagree with me, get yourself a Pioneer drive! you won't regret it, they cost around 60$ and are worth every cent!
Best Regards,
Sefy Levy,
I have a liteon 16x dvd drive,paid 50 bucks and after upgrading the firmware i average about 8x rip speed peaking at 16x.
I have a Toshiba but it's all Dell puts in Laptops
I get 2.3-1.5x i just live with it.
Set it n go do something.
heres a good one
i brought a 16x memorex cdrw a while ago and a floppy came with it with a supposed high speed cdrw driver on it i thought what the hell in for a penny in for a pound and installed it
and to my surprise the side effect of this was my ripping speed with a 10x pioneer went from 2-3x to 7-8x
i then uninstalled it and the speed went back down to 2-3x
so reinstalled and up it went
i also have the most up todate aspi layer from roxio which helps also
if any 1 wants to try this driver p/m me and ill email to you as its only tiny -
I have samsung 12x and with DMA enabled rips at 4x(use to rip at 0.9x with DMA disabled)
Pioneer 16X is one of the best DVD-ROM on the market.
PIONEER RULES!!!!
I am going to get one very soon. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Thanks Sefy! I was wondering as my rips using unencoded DVD's always seem to go so much faster and I was wondering if it could be something to do with the decode step or if it could be something else..?
Thanks!
- bewley
Ziggy In Concert
bewley, most of the speed is the actually access to the DVD and the copying from it, and Toshiba DVD's suck big time! and trust me, i'm not the only one who says it.
Best Regards,
Sefy Levy,
Sefy,
I don't have a Toshiba... Hell, I'm not even sure the brand I have... It's just that I have a few *ahem* mature titles that are not encoded... These fly when I rip 'em, but all my other encoded DVD's take much, much longer... I have a PIII-550. Maybe that's the problem?!?
Thanks,
- bewley
Ziggy In Concert
bewley, well, I sorta doubt it, as i've mentioned, decoding does not take that long, and it's not even done when copying, it's done prior to copying, if you notice Smart Ripper first looks for the key, then it starts copying the movie.
That's why I said the decoding is not what usually takes the time, unless you can actually see the process holding a long time while Smart Ripper is looking for a key.
Best Regards,
Sefy Levy,
Hmm.. I have a Pioneer that offers me nothing but headaches (rips slow, but the real problem is REGULAR CD's)... I use it for DVD's only, as that's the only thing working flawlessly with it.
I also have a Toshiba 6x DVD-Rom drive as a backup for one day installing into my Apex 500W (when its drive craps out)... Spec-wise, it's a better unit.
Side note too... I owned a Pioneer 343 for all on an hour, it was the worst peice of crap hardware I had ever seen.
Pioneer doesn't seem to have a good track record in homerpez-land. Are you SURE they're good drives? Maybe I just need an upgrade (after all, I'm only ripping 1.3x WITH an ASPI layer in XP...) -
maybe your Poineer is fukked my Pioneer can reach up to 10 speed and sumtimes up to 12 speed but mostly 6.0
maybe my Pioneer is only a 6x drive? I'd have a heart attack if it ever did 10x!
well i was shocked when it reached that speed and even more shocked when it reached 12 speed..i almost fainted
Well, then you two better seat down and grab on to something, cause my 16x drive just hit 15x rip speed on a Disney Cartoon! if you are interested in details, it was The Little Mermaid
Best Regards,
Sefy Levy,
ArcSoft Showbiz DVD 2 Smart Rendering
By zulubase in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 21:12 -
get smart doesnt work with DVD Fab
By shoesss in forum DVD RippingReplies: 6Last Post: 7th Nov 2008, 11:52 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
