I'd like to start this topic on AviSynth from the very beginning. Hope you can help. As I try to install it, there's an option to associate files with notepad and media player. What should I do?
TKS
Results 1 to 14 of 14
I never tried to associate with mediaplayer. I select Notepad, and when i want to view an AVS file i open it in virtualdub, mediaplayer also once in a while. My advice would be to put shortcuts to WMP and Vdub in the SendTo folder, then you can simply right-click an AVS ffile and choose Send To -> Mediaplayer to view.
I'd add an edit option to the shell and associate that with notepad, ultra edit, etc. So double click = play, right click-->edit = notepad. Something else usefull is to add avs to the new document shell so that you can easily create a blank script to edit.
As for using AVISynth. Like most things. All else fails. Read the instructions. -
Did you read the instructions yet?
What exactly do you want to use it for? -
- Sure I did!Did you read the instructions yet?
- I want to learn how to use it as a FrameServer, wanna know how to add filters, deinterlace, credit roll, convertions, etc. Some people say they don't even use GordianKnot anymore but only AviSynth. Of course those are advanced users since I can't even make GK convert MPEG2 to Xvid.What exactly do you want to use it for?
So, as far as I know AviSynth is a FrameServer. I guess I'll open my AVIs with it and frameserve to VD, for titles, filters, transitions, etc....as jimmalenko has said around here. -
I think this is one of the best places to start:
http://www.avisynth.org/index.php?page=YourFirstScript
Follow the links from there when you feel ready. Reading is not enough, hands-on training is the only way to remember all you read, so try things out. Begin with testing the AviSource function, move forward from there =) -
Hmmmmm, well, thanks for you help. I've already read all those isntructions. Now, back to that question: which option shoud I choose when the installer asks me...
1.Associate AVS files with Notepad;
2.Associate AVS files with Media Player 6.4
(I'm not kidding here)
THANKS>>>>>>>> -
Read my blog here.
Capturing VHS for newbies/dummies
By tj- in forum Capturing and VCRReplies: 6Last Post: 10th May 2011, 15:19 -
Update- So what programs do you use? (attn newbies too)
By Super Warrior in forum DVD RippingReplies: 6Last Post: 12th Jan 2009, 13:45 -
Newbies first post - FInalcut + what?
By fontenele in forum Newbie / General discussionsReplies: 0Last Post: 7th May 2008, 18:34 -
[4 the newbies to the Internet] About the trolls
By Midzuki in forum Off topicReplies: 6Last Post: 15th Apr 2008, 09:04
