Ok so if I take a dvd that I have and back it up using DVDX COPY Platinum, making just a copy and letting it do all the work it works just fine and dandy on my PS2 and all the other dvd players in my house, but I have tried taking movies that I have on my computer, and using Nero DVD-Video option, and burn the files that I have on my computer, it does not work on my PS2, yet works just fine on all the other dvd players in my house. I have a good quality DVD burner(NEC 3520) and good quality discs, Taijo Yuden, does anyone know what the deal is and how I can rememdy this, thnx in advance!!
What are you using to author the movies? Maybe PS2 cant read the files in the current format ie avi, or mpeg.... I have used TMPGEnc DVD Author on -r disk and they work fine.
yeh,dont use nero.
try ripping a movie with dvddecryter,if its a dvd5(previously backed up movie on a dvd-r),then pick iso read,iso write,and see if that works.
it should do,and for original movies,use dvddecrypter,then dvdshrink to make them fit a dvd blank,then burn with copytodvd,or like minded software,giving nero a wide berth and that should be the problem solved.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
i was not authroing the dvds per say i guess, just letting DVD X Copy do all the work, or nero do all the work, for dvd that im not making a copy of, i basically have the video_ts file on my harddrive, then open nero DVD-Video option, selesct the file and it gets er done...but dont work on the PS2 unless I do a direct copy using DVD X Copy, which i guess shrinks it for me and all that good stuff.
Ill try using that DVD author program I guess, since DVD X Copy makes it all work just fine for me -
I haven't heard muchabout DVD X Copy for a year. IF it works for you just keep using it.
those tools i mentioned are freeware.
i just thought you could try it once,and see.
ive replied to a few people with similar probs to you,and its worked for them,funnily enough.
just another workaround i guess,but it does solve the dvdlab bug.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
PS2 DVD Region Free Code
By THRobinson in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Dec 2010, 11:59 -
PS2 and DVD info from region1 moving to region 2. confussed totally here
By joelliott in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2010, 15:52 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Playing ripped dvd in ps2
By hrgrosskopf in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 08:04 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 11:07
