Hello all
I am a total NooB at VCD burning. I downloaded a few movies in .avi format. I then used tmpg to convert to VCD format. The mpg is 1gig is size. I guess I now must cut this in 2 and put it on 2 CD's? I used mpeg tools in tmpg went to the cut tab, loaded the file went to edit, hit the [ at 00.00 then hit the ] at 51mins which is half way through the movie. I then hit Run and I get a floating point error. what am I doing wrong? I cannot cut any of my Mpeg 1 files, I tried 2 different files.
Also it takes me about 1 hour and 10mins to convert a 700meg avi to VCD is this fast?
My system is:
AMD XP 1800+
Abit kr7a Raid M/b Via kt266a
512megs DDR ram
2 X 30gig IBM Hd's in RAID 0
TIA
MosH
Results 1 to 1 of 1
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
Judder from converted 23.97 divx avi's.
By strutter_uk in forum Authoring (DVD)Replies: 5Last Post: 28th Jan 2009, 08:30 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22
