I think I posted it about it before but I can't seem to find it.
I've been OTR the last couple of months but I'm now going to be home every weekend.
One of my small projects is to convert my PAL VHS tapes to editable format like AVI and then convert it into DVD format for use in my DVD player.
I saw a simular post but not an ATI specific post. The ATI will take a PAL signal in and do the conversion or will output PAL to the PC screen so I can see it.
Is that correct?
If that's the case then all I need is a Multisystem VCR that outputs in PAL and no converter onboard? That would save at least $100 if not more. But I have though about buying one anyway since I don't have a VCR and I'm not sure if the Sony N-700 HiFi VCR we have will have the same problem with out Tivo units. Which is it takes the recorded signal from the Save to VCR line output but records it on to video in Black and White, not color. I fear the Sony will treat my ATI card no different and give me some soft of macrovision error like I think we're getting with the DTV Tivo unit.
I would like to start this project soon so please help me! lol
Project Digital: Eliminate All Physical Media is finally underway!
My sister inlaw is from chez republic and she wanted to do the very same thing. She bought a pal playing vhs player and we hooked the scart cable to the ATI card. I changed the settings in the capture device to pal m I believe and converted a hole bunch of things for her.
MPG or AVI will work fine just adjust the settings. -
That Dun, just what I wanted to know. I should have bought that Multisystem I saw for $70 and the guy was right here in LA! Darn it all...
I'll pick one up in the next couple of days and start this projectProject Digital: Eliminate All Physical Media is finally underway! -
from what ive read, the ati cards either do pal or ntsc, not both
A penny saved is a waste of time. One in the hand is only worth 0.5 in the bush. A stitch in time saves nothing. -
ATI cards can do both PAL & NTSC, but ONLY on the Composite/S-Video input.
The TV-Tuner input is restricted to PAL OR NTSC (not both). -
He's correct -Originally Posted by Sulik
When you buy your All In Wonder or TV Wonder there's a check marked on the box that says PAL or NTSC.
In your MMC software you can switch to any format available when using the break out box.
I just haven't picked up a player yet.. Been working on the car
NTSC to PAL Converter and Vise Versa
By rockonvidtrade in forum Authoring (DVD)Replies: 14Last Post: 8th Apr 2013, 18:28 -
how to test Pal/Ntsc converter box?
By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2009, 11:28 -
PAL-G to NTSC converter
By whizzkid in forum Newbie / General discussionsReplies: 0Last Post: 11th Jan 2009, 19:30 -
is there any PAL to NTSC DVD converter?
By mvp in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2007, 00:38 -
Anyone Ever Heard of Digital Media Converter Pal to NTSC
By mn072065 in forum Video ConversionReplies: 5Last Post: 9th Jun 2007, 22:50
