Hello,
I am currently trying to back up my copy of "Sideways". I am using Dvd Shrink and Dvd Decrypter. As soon as I start to write the file to dvd-r I get and error. The log is as follows:
I 16:47:41 DVD Decrypter Version 3.5.4.0 started!
I 16:47:41 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 16:47:41 Initialising SPTI...
I 16:47:41 Searching for SCSI / ATAPI devices...
I 16:47:41 Found 1 DVD-ROM and 2 DVD±RWs!
I 16:48:50 Operation Started!
I 16:48:50 Source File: C:\DOCUMENTS AND SETTINGS\KINNEY FAMILY\MY DOCUMENTS\MY VIDEOS\SIDEWAYS_169.ISO
I 16:48:50 Source File Sectors: 2,285,848 (MODE1/2048)
I 16:48:50 Source File Size: 4,681,416,704 bytes
I 16:48:50 Source File Implementation Identifier: DVD Shrink
I 16:48:50 Destination Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D(ATA)
I 16:48:50 Destination Media Type: DVD-R (Disc ID: z2s7333233)
I 16:48:50 Destination Media Sectors: 2,298,496
I 16:48:50 Write Mode: DVD
I 16:48:50 Write Type: SAO
I 16:48:50 Write Speed: MAX
I 16:48:50 Link Size: Auto
I 16:48:50 Test Mode: No
I 16:48:50 BURN-Proof: Enabled
E 16:49:54 Failed to Reserve Track! - Cannot Write Medium - Incompatible Format
E 16:50:08 Operation Failed! - Duration: 00:01:18
I 16:50:08 Average Write Rate: N/A - Maximum Write Rate: N/A
Can anyone please help? Thanks in advance.
Go to Tools->Settings->I/O tab and set transfer length to manual/32kb and buffer length to ~75MB.
If that doesn't help reshrink the movie to <4,400MB(4.62GB). -
Why not search the board for this film? Use DD on it then shrink then write with DD.
Thanks for the info MovieGeek. I tried your suggestions but am still getting the same error.
Handyguy, thanks for the tip on checking the board first....I had never thought of that. I had already checked before posting and your "solution" of "Use DD on it then shrink then write with DD" is also something that was done and failed well before posting. But thanks for trying. -
I/O errors are bad, scratched or dirty discs. I've had the same problem that cleaning fixed one, DVD Scratch Dr fixed one and one that was beyond repair. Check DVD Decrypter's website and you'll find they say the same thing.
yeh true,its either a media error,dma on the drive,disc just doesnt like the drive,
LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Seems like the rip goes well, but it's writing the disc that fails, right? Using new media brand or something?
/Mats -
I'd agree, as described, sounds like it is more of a write issue than a rip issue. The only thing I'd suggest is changing the write speed from MAX to something like 4X to see if it will at least start to write something. I also don't recall you saying whether your previous attempts have resulted in coasters, which would suggest that it is at least writing to the discs.
Is it possible that your drive just hates the type of media you are using and does it show on a compatibility list? I know that I've got some old OptoRite dvd-r's around here that my Pioneer just hates and spits them out almost immediately like bad food.
Easy way to default existing subtitle to "on" when backing up?
By Spoffo in forum SubtitleReplies: 1Last Post: 30th Jan 2011, 21:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Problem "backing up" Confessions of a Shopaholic
By jamesprime4328 in forum DVD RippingReplies: 4Last Post: 3rd Sep 2009, 14:15 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
Burning my first DVD home movies with Pinnacle, "disc error" on D
By tony777 in forum Authoring (DVD)Replies: 2Last Post: 13th Jul 2007, 21:07
