  1. I loaded an avi file. Then I loaded the vcd (ntsc) template. I change the video source ratio to 1:1 vga. After I converted the movie, I can see the souce but the screen is blank. HELP! What should I do???
  2. You can see the source, but the screen is blank... Oxymoron?
    What do you have your preview setting set at (under options)?
    Take a look there.
    Troy
  3. Oops. I meant that I can view the source avi (no blank). The vidoe on the output mpg file is blank. Sorry for the confusion.
    My Preview option is Display with thinning
    Fix to 320 x 240
    Automatically resize the winfow for Preview
