In my Sony DV camcorder I have two options for recording sound. One is PCM 16 and the other is PCM 12. I assume that they differ in quality but the difference is unhearable for me. Is PCM 16 worth using or is it only... erm... for fun? I'm afraid that turning PCM 16 on will eat some of the kilobytes that would normally be used by video data. Will it?
Results 1 to 10 of 10
I have no idea why Sony insist on giving you the option of 12 bit PCM, it is of no use to anyone. If the camcorder is set at 12 bit, when you transfer your footage over Firewire (i-Link) to your pc, you'll have 32kHz audio. 32kHz audio isn't DVD compliant so you'll have to upsample it. Set the camcorder to 16 bit and the audio will be DVD compliant 48kHz.
Please, people, don't use that 12bitPCM at all unless you truly have to eek out every available minute!
Default for DV camcorders should be 16bit, PCM, Stereo, 48kHz. If yours isn't set to that, you're doing yourself and your mates a disservice.
You may not hear the difference from camera headphone jack, but you'll definitely hear the difference on PC or Receiver speakers.
16bit ~= 96bit signal to noise, 12bit ~= 72. That's AT BEST with full signal.
also
48kHz gives 0-24kHz bandwidth, while 32kHz give 0-16kHz. Not so noticeable, but still important for music.
Scott -
I agree 16bit, 48KHz should be the default. It will produce audio that is directly compatible with DVD.
12bit 32Khz has only one advantage, the ability to mix down to a second stereo audio pair of tracks.
Consumer models allow narration or music to be added to a second set of stereo tracks after the main tracks are recorded live. A mixer function is provided in the menus to weight the main tracks against the narration/music tracks during playback.
Some prosumer MiniDV models allow direct 4 channel recording in the live mode. Model features vary but usually the built-in stereo mic is recorded to the main tracks and the external Mic/Line input feeds the second stereo pair. The external input can be used for wired or wireless mics or house sound.
4 channel mode will record in lower quality but in some cases the extra channels are useful for post mixdown. -
I've been told that the Japanese are fond of doing this, thus everyone gets 12bit/32kHz as the default. ARG...Originally Posted by edDV
No, not unless you create it.Originally Posted by nwo
With a prosumer camcoder capable of 4 ch live recording, you could place your 4 microphones for surround, then author to AC-3 later. I'd do it left, center (voice), right and rear.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You need to rent a prosumer 4 input camcorder at this level.Originally Posted by nwo
http://www.dvwonline.com/products/sony/dsr-pd150.html
Consumer models have only 2 inputs. You can add tracks 2 at a time, two with video and two after.Recommends: Kiva.org - Loans that change lives.
How do you convert DTS to PCM
By ChrisDaMan in forum AudioReplies: 27Last Post: 29th Jan 2013, 02:32 -
parse ts pcm stream
By niror in forum AudioReplies: 2Last Post: 2nd Oct 2011, 01:36 -
iv50 pcm?
By dinofava in forum Video ConversionReplies: 9Last Post: 11th Oct 2009, 09:33 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 04:34 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 10:53
