How can I make the connection bellow? The menu1 is 4:3 and the Movie1 is 16:9, and I have the movie7 in either 4:3 and 16:9 formats, but with either ones the dvdlab suggested me to create another vts, but how can I make this connection now?I am trying to insert a video to be played before the menu1 appears.
Results 1 to 9 of 9
Click the bridge tool.
Link like this:
Cheers, Jim
My DVDLab Guides -
Ok, before I see your answer, I had made, but as my "movie 2" was in another vts, The program told me tho create at least an empty vmg menu.
I would like to ask you now, if there is a way we could grap a lot off objects at the connections window, the be an easy way to arrange them, do you know? Or an automatic arrangement tool, do you know? -
Nope. Just arrange them so you can see what goes where.
Cheers, Jim
My DVDLab Guides -
How can i do that but instead of timeout menu i have a button inside(VGM Menu) that i want to link to a menu(Not root) in the VTS???
Right click on the button and link it wherever you want, or link to another bridge, then to the menu.
Cheers, Jim
My DVDLab Guides
how do i edit menu connections on an existing dvd?
By animalia in forum DVD RippingReplies: 7Last Post: 14th Jun 2010, 03:42 -
Question about transferring HD-DVR to DVD connections
By kevin75 in forum DVB / IPTVReplies: 1Last Post: 29th Apr 2008, 12:03 -
Having problems with HD connections, TV-DVD
By 1234567 in forum DVB / IPTVReplies: 35Last Post: 7th Feb 2008, 07:04 -
DVD Lab - Movie/Title order in connections view
By BeachNut in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 16:17 -
VHS to DVD: what connections to use?
By Stabes in forum Newbie / General discussionsReplies: 7Last Post: 14th Jan 2008, 00:05
