when i back up my dvd's using dvd shrink and copy the backed up dvd to a blank dvd they seem to work fine on my dvd player i have in my room which is not an expensive one. So then i tried to play it back on a sony dvd player which i have in my front room and it wouldn't work. Do i have to set it as region free in dvd shrink?
sorry for all question as you can tell im a newbie!!!
Thanks again
Yes, although it should do that by default. What media are you using (brand) ? Are they + or - R ? What type of disk does your Sony expect ? Have you checked out your model Sony in the Players list (to your left) to see what disks other have trouble or success with ?
What, if anything, does the Sony say when you put the disk in ?Read my blog here.
Generally cheap far-east dvd players play everything.
Expensive brands e.g Sony don't. -
Well there you go. Your Sony does not play pal, region free won't work for you. You either need to try patch method or convert to NTSC
BTW. I have 2 Sony's that I use patch method on it works.
https://www.videohelp.com/forum/viewtopic.php?t=221928
This will not work on SOny PS2 though
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 05:35 -
Blu Ray Player won't play some DVD backups
By Turpulus in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Apr 2009, 03:00 -
What do I need to do for making backups to play on PS3(japan)
By korazy in forum DVD RippingReplies: 4Last Post: 27th Dec 2008, 14:50 -
DVD Backups play in PC, not dvd players.
By chewbeeb in forum DVD RippingReplies: 7Last Post: 22nd Dec 2007, 02:26 -
Updated PowerDVD wont play HDDVD backups
By aye29 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 05:58
