I attempted to read the media info for a blank Verbatim 8x +R DVD and the software returned the following answer: "Your drive does not support the commands required to read the MID codes on this media" I was able to read the info for a disc that was used and it indicated the media code was RICOHJPNR01. My DVD writer is an early model Plextor. It is the PX 504A. I recently upgraded the firmware to the latest version. This all started for me while I was deciding on which Verbatim media to purchase. I had purchased some DVD+R 4X last year and I wanted to buy some more. I went to one of our Staple outlets and they had some Verbatim DVD+R 8X on sale. I was quite suprised that the 4X were so much more expensive. Is there a difference in quality between the ones rated at 4X as opposed to the ones rated at 8X?
Ron
Use another one. There are more software.
Firmwares of real old burners (like the PX-504, a rebadged NEC ND-1100) don't support checking the id on blank DVD+R/RW media.
Wanting more info on video rendering and creation software
By spiralthinker in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2011, 13:51 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58 -
Playout software for info TV
By mivari in forum Software PlayingReplies: 0Last Post: 12th Sep 2009, 08:11 -
Software to view technical info of dvd video
By cengoh in forum Software PlayingReplies: 3Last Post: 28th Sep 2007, 03:59 -
JVC 'pro' edit deck - any info?
By Quasipal in forum RestorationReplies: 1Last Post: 9th Aug 2007, 06:24
