I have a question regarding ffmpeg's DVD encoding calculation.
Let's say I put a 3ivx movie in that's of high quality and want to use the DVD mpeg2enc preset to encode it.
Its seems no matter what the source is, ffmpeg tells me when i click "best", that 2994 k/bits a second is the best rate according to 720x480, film frame rate. And then i will have to letterbox it. How can i encode video but let the player electronicly letterbox it?
If this is optimal than why are some DVDs very hit bit rate like in the 6Ks and 9Ks?
DVD size is always 720x480, with our without letterboxing (simply use 'Decode with Quicktime' for autoletterboxing). For 16:9 aspect select "DVD 16:9" autosize (the size will still be 720x480). The bitrate is optimized for ffmpeg engine. With mpeg2enc you may pump it up eg. to 4000.
iTunes + Windows XP 64 bits, how?
By NormaJ in forum Software PlayingReplies: 11Last Post: 29th Dec 2010, 22:14 -
Vista 64 bits with 32 bits programs
By skaleton in forum ComputerReplies: 9Last Post: 15th May 2009, 11:41 -
SVCD2DVD crash on xp 64 bits
By alkirah in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Jan 2009, 08:17 -
How to go over bits of a movie... editing sound
By UmmAddan in forum EditingReplies: 2Last Post: 22nd May 2007, 18:58 -
Why would the bits/pixel drop?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 8th May 2007, 03:55
