I have a DVD that is playing slightly tall. I think it was authored improperly, the characters etc. are all a little stretched so they look just a little squeezed tall.
Is there a way to re-author the disc without adding a generation to the encoded video and get it stretched proper? (a little wider)
-thanks
It sounds like it is a 16:9 anamorphic disk, but doesn't have the 16:9 flags set correct. Demux the video and audio, then use restream on the video file to change the AR flag to 16:9, reauthor and you should be OK.
Before you get too carried away, is you DVD player set to display 16:9 as letterbox (assuming you don't have a widescreen TV, of course).Read my blog here.
Reauthor a DVD to play all
By burgherboy in forum Authoring (DVD)Replies: 10Last Post: 7th Jul 2011, 20:46 -
Trying to reauthor with dvd shrink
By StoneColdWhat in forum Authoring (DVD)Replies: 2Last Post: 6th Feb 2010, 17:26 -
Wrong image size ratio after AVI to DVD encoding
By video34bgi in forum Video ConversionReplies: 2Last Post: 22nd Jun 2009, 10:45 -
Reauthor a DVD with new audio
By nuguy47 in forum Newbie / General discussionsReplies: 2Last Post: 27th Jul 2008, 12:19 -
I want to reauthor an episodic dvd
By peterhun in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2008, 18:02
