HI,How can i tell if my sound card is bad. I am trying to capture footage from dv to my hd, I am using windows movie maker and/or MGI video wave. I am able to capture the video footage but cant get any sound with either program. thanks for any help
Need more details..what version of videowave? I am quite familiar with it. Exact method of transfer? etc. The settings of "something" is most likely the answer unless your sound card is fried then you'd probably know it already. Peace
Her name is Laura. She loves my bush. -
Originally Posted by npaulie2000
if the sound is coming out of the camera then it is "there" plug the audio output in to your sound card directly maybe via your microphone plug and adjust your settings accordingly. I had the same problem before CHECK ALL YOUR SETTINGS in every program involved in the process..Peace
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
