  1. How do I know what my "source aspect ratio" is??
  2. What type of source are you using?
    If it is a DVD, then you can usually tell by looking at the package -- "standard" is 4:3 and "widescreen" is 16:9. If you are dealing with VCD, XVCD, and SVCD, then it is most likely a source aspect ration of 4:3. AVI and others often are 1:1.
    Hope this helps.
    - bewley
    bewley's mp3PRO Rock
    classic/metal/new rock streaming 24/7
    Ziggy In Concert
    david bowie unofficial discography
