I am looking for a good free program to edit the tags of my mp3's. What seems to be the most popular program? It would be nice if it did WMA too but that is not necessary. Thanks
Results 1 to 10 of 10
Id3-tagit seems to be the best option. Yes I did a google search before I posted this but it seems like everything that comes up is a free trial and it expires. Thanks for the help.
You did?Originally Posted by ddawson24
strange... its right at the top of search...
Yes I did the google search. I actually have had id3 tag it installed on my computer for quite some time. I know how to use a search. id3-tagit does come up first. But it also does crash and it doesn't do wma like I said it would be nice to find something that does wma as well but it isn't absolutely necessary. I was hoping that maybe somebody knew something else and instead of searching through google for three years of programs that are free to try for 15 days and then you have to pay $20 for them there is something that is free and better and you can just donate the person who made the program money rather than be forced to pay. So I figured if I brought the topic up than if later on someone has the same question it can be found through the search function on the forums too. So far I am just sticking with id3-tag it. Thanks
@ddawson24
As I told you in my first reply:
. . . M E D I A . . . T A G G E R. . .
Since youre unable to find it yourself, here is damn link:
http://www.volny.cz/media-tagger/eng/
IMO its the best id3 tagger (and more) i have tried so far.
Yes, it is freeware.
from the site:
EDIT:Feature:
+ Full support MP3, VQF, WMA, OGG, APE, MPC, AAC and FLAC files.
+ Additional (lossless) formats Speex, WavPack, OptimFrog, Lossless Audio, LPAC and TTA.
+ Tags support ID3v1, ID3v2 Lyrics & Pictures, Lyrics3 v2.0, APE version 1&2, Vorbis comments.
+ Easy multi-file tags editing and renaming.
+ Creating Winamp compatibile PLS, M3U and B4S playlists.
+ Downloading TAGs from FreeDB and LocalDB database (www.freedb.org).
+ Export file list and tags to the (.txt, .nfo, .diz) text files, CSV text files and HTML pages with using Template files.
+ Internal file player (mp3 and wma only).
+ Play your multimedia files in Winamp while editing Tags.
+ Swaping TAG fields and char case formating.
+ Checking file length for 64 chars (on CD).
+ Fixing track numbers.
+ ID3v1 and ID3v2 synchronizing.
+ Multilanguage support.
+ Store settings and other data in .ini file.
+ Drag & Drop support for opening files and pictures.
+ Integrate in system context menu.
+ Formating filename form TAG, and importing to TAG.
Don't forget to donate whatever you can, even a dollar (if you'll like it ofcourse - and Im sure you will
MKV Tag Editor
By gonwk in forum Newbie / General discussionsReplies: 32Last Post: 24th Jan 2021, 10:39 -
Any free ID3 or music tag editor/tool that can convert character set.
By csh in forum AudioReplies: 1Last Post: 17th Jun 2012, 12:09 -
WMA tag editor / renamer
By olyteddy in forum AudioReplies: 5Last Post: 13th May 2009, 11:37 -
Can Anyone Recommend a Good Audio and Video Tag Editor?
By Nitro89 in forum ComputerReplies: 1Last Post: 23rd May 2008, 03:16 -
Possible ID3 Tag Problem
By Graham099 in forum Authoring (DVD)Replies: 0Last Post: 11th Jul 2007, 07:45
