Results 1 to 12 of 12
  1. Just a quick question; what is the difference between the two
    If [in vcdeasy for example] I have the option which is best?, my DVD player lists 1.0/1.1/2.0 in its compatability list
    I take it 2.0 would be the one to go for?, or does it not really matter?
    canada
    Dont really matter,use vcdeasy 1.152,free and no major difference in the commercial version.
  3. Banned
    Aug 2002
    beautiful
    1.0 won't have menu or chapters,
    2.0 allows for chaptering on a single file & menu (aka PlayBack Control = PBC)
  4. Nah John mate, not which 'version' of vcdeasy I meant which one of the actual VCD standards to use
    Cheers Derex888, looks like 2.0 it is
  5. Banned
    Aug 2002
    beautiful
    there are more differences than that, but you could google it and get 1000 hits probly...
  6. VCD 2.0 supports PBC, or playback control. That is, you can have menus, and the like.
    VCD 1.1 does not (the VCD player will just play the disc from beginning to end -- i.e., like an audio CD).
    Regards.
    Michael Tam
    w: Morsels of Evidence
  7. Banned
    Aug 2002
    beautiful
    Regards.
    hmmm...
    did my reply didnt show up or something
    You basically repeated what I've wrote previously
    Vitualis, do you have me on some sort of 'ignore his posts' list/option I dont know of?
  8. Sorry, didn't see your post...
    Regards.
    Michael Tam
  9. Banned
    Aug 2002
    beautiful
    hehe no problem, I just thought that you had me 'ignored' or something =)
  10. Originally Posted by DereX888
    Mhhh.... it's easy to ignore your post with your avatar ! I'm kidding!
  11. Banned
    Aug 2002
    beautiful
    Don't worry, when you reach certain age it won't bother or distract you anymore
    Feb 2001
    https://www.videohelp.com/vcd#tech2
    Each version added new features, eg. menus, additional resolutions to support PAL video, support mixing PAL and NTSC on one disc.
    For additional specifics, get the Philips VCD toolkit - it's in the docs.
    /\/\ars /\/\ayhem
