Results 1 to 10 of 10
    May 2004
    Tryied to back it up using dvddecrypter, but i keep getting errors at about 42%. Any ideas on a programs that can back it up with no problems?
  2. DVD Decrypter? I used either that or DVD Shrink for my disc, Decrypter should work fine I'd think.
  3. Make sure you have latest version maybe?
    Quality is my policy.
    May 2004
    Well, I updated my DVD Decrypter, but I am still getting the error. I have used my DVD-Rom and my DVD+-RW with many of my other DVDs, so I know that that is not the problem.
    This is my error message:
    I'm stumped here. I can't use DVD Shrinker. I get this error message:
    Any help will be appreciated.
    Much Love!
  5. Hmmm, weird you are having this issue. I just backed up Master & Commander 2 days ago using just DVDShrink. Of course, I had to re-author for movie only, which still had about a 74% compression.
    Maybe trying a different DVD drive will work (nevermind, just re-read your post which you said you did). Maybe an issue with your disc? I've received an error similar to yours before when trying to back up The Rock. Didn't matter which drive I used or method, it always would crap out at about 80%.
    Mar 2004
    Have you tried cleaning the disc?
    I had no problems with this disc, and I used DVDShrink.
    -Bruce
  7. It sounds like it may be the disc itself. You could try to rip it with DVD Decrypter and select the option of 'ignore read errors'. That or ISOBuster would be the last resort, short of trying to fix any scratches that may exist on the disc with something such as a disc doctor.
    May 2004
    Tried the "ignore" option in dvd decrypter, but the whole process freezes up anyway. I also tried ISOBuster, but no dice there either. I will try another disk. Thanks all.
  9. hi ive had the same problem, the issue in my case the disc where scratched. just this weekend my nephew brought me some of his dvds, he was in the desert and the sand messed a few up. he asked me to back them up before they got to worst. ssome after some good polishing they eneded up being able to back them up the others where to damaged. so try buffing them and i'll bet it will work
    May 2004
    I tried cleaning the disk with window cleaner as advised by the website, but it didn't help. Anyone have any good cleaning advise?
