I'am noticing some freezing with MPG's that are converted to NTSC from PAL , this was a not a issue with RC7 and below ?
i first thought they were bad burns so i tried 2 different burners with same results also tried 3 differnt media types and still same result .
so i tried burning the the orginal mpgs in pal format and there is no freezing ?
weird thing is that if i play the VOB file from HD using Power DVD it does not freeze but once its burned to DVD it freezes in MY PC and in at least 6 different DVD players ranging from Phillips to Apex to samsung and with the same with results and unfortantely i no longer have RC7 to test and see if it is RC8 and the way its converting the MPG's to NTSC ?
by the way used nero burner , nero 6 , and tmpgenc author to burn disk and all with same results .
also freezes are short pauses for sec then it starts up again and every dvd i have burned regardless of method has the same problem at the same points in the mpg
Results 1 to 18 of 18
So, let me see if i have got this right: if you play the VIDEO_TS folder from your HD in PowerDVD it is ok. Then if you burn the VIDEO_TS folder to DVDR and then play it back (with PowerDVD) you get freezing?
I can send you RC7 if you want to compare? Email me for this.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
yea thats correct ?
ok i'd like to test it to see if its just the mpgs or rc8 ?
just try to rule everything out ...
i'll pm you -
i'm having the same problems with PAL to NTSC conversion. I had the same problems with release 7. DVD plays fine on pc but i get freezing and audio is skipping when playing on 2 different home DVD players. I believe I didn't have this problem with release 1 but i don't have that version of the installation anymore.
just tested RC7 out and still the same problem
Original MPEG details
mpeg2video
Pal
480x576
2207Kbps
NO
MP2
44100
224Kbps
plays fine from harddrive but once burned it freezes and the same points on every burned DVD , ive burned at least 20 times , if i leave it in pal format it works fine . -
a new problem is when i make a dvd using 1 VTS it does not make chapters ?
EDIT: this issue was fixed by reinstalling Net framework -
any idea on this chrissy ?
2 different PC's and different burners on each PC and 1 PC has RC7 the other has RC8 but both have the same problem ?
the only thing that is exactly the same is windows xp pro which is the same copy installed for both PC's
i made a new pc and formated both PC's and started from scratch and it seems that since the new build ive encountered the problem i didnt have this problem before the new build ?
i'am thinking i will format 1 of the pc's and see if that fixes anything ?
and try a different copy of windows xp
and suggestions would be greatly appreciated -
I am developing a new method for pal to ntsc within the program. Hopefully it should resolve your issue. Drop me an email and you can test it tomorrow (or a soon as it is ready).
ThanksSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I would be interested in testing this as well, as I am experiencing the same problem.
crissy, i am also encountering the same problem with PAL to NTSC, and was wondering if i could test your new conversion method, my email is sockapo@gmail.com, thanks for your time
Yes well i would like you all to test but i have had to rebuild my PC today so it will not be a soon as i would have hoped..... (On with the progress bars
I am having the same problem but for me, it plays fine BUT the picture is VERY distorted. Like the pixels are messed up or soemthing.
Also when i convert from PAL to NTSC, AFter i extract the .bin and when i'm bout to drag the mpeg to the VTS layout. I noticed the file size has sunk down to only 15 megs. -
Is there a fix in the works for this issue yet? Every PAL to NTSC conversion is studdering & freezing with 8....Thanks
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL/NTSC issue
By redbaron88 in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2011, 09:25 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
capturing on sony hdr-hc7 NTSC Tape / PAL Camera issue ?
By DKmickey in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Feb 2009, 14:38 -
PAL + NTSC Compatibility Issue !?
By ells6363 in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2007, 12:37
