There is a TV series I have been ripping with DVD Decripter. And burning with Ulead. Is there a way of puting together two different episodes on a DVD-R without useing an edit software? Whenever I try to eliminate an episode before I use DVD Decripter, the final DVD-R turns out NG. Is DVD Decripter no good for this sort of thing. Is it Ulead? Where is the problem occuring? If I have to use an edit software, which is good for working with ripped DVDs?
I would use DVD decrypter to rip the contents of each disc of source material to a seperate folder on your HD. Then use File Open to open the directory of each disc, go into re-author mode, and as long as each episode is a seperate title you should be able to drag the individual titles from the right side of the re-author window to the left side of the screen where you have your compilation.
Here is a guide:
http://www.dvdshrink.info/reauthor_basic.php
This guide shows how to rip selected titles from one disc to a new compilation using re-author mode. You can actually drag a couple of titles, then open another disc, and grab a few other titles, if the episodes you want span multiple discs.
Each episode would play back to back, with no menu in the order that you've set them up. Also I think there are more advanced guides that tell you how to add menu's...
Need to burn TV episodes to DVD
By harishkumar09 in forum Authoring (DVD)Replies: 44Last Post: 3rd Mar 2013, 05:35 -
As many episodes as possible on one DVD5
By nharikrishna in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2011, 07:56 -
Best Method for Converting S-VHS and Bringing into Sony Vegas
By Great Googly Moogly in forum Video ConversionReplies: 9Last Post: 20th Mar 2010, 08:30 -
Re: Multiple TV episodes, only decoding the first one
By Franknstein in forum ffmpegX general discussionReplies: 2Last Post: 10th Apr 2008, 23:46 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 15:09
