Hi. I'm converting from AVI to MPEG2, so that I can burn to DVD. I've recorded sport with very fast camera panning so I've decided to make it 50fps by splitting the two fields. Is there a program that supports converting to MPEG2 @50fps? I've tried TMPGenc and it tells me that 50fps is unsupported. 25fps is just too choppy so I really need 50fps...
Mark.
Standard PAL TV is always 50 fields per second. If you convert to 25 fps interlaced your video will be displayed at 50 fields per second on TV. Just be sure to get the field order right.
Matrox AVI, 50fps and Adobe...?
By dr_shabzzz in forum Video ConversionReplies: 1Last Post: 17th Sep 2011, 08:53 -
Editing 50fps - best workflow?
By Jeffboy in forum EditingReplies: 3Last Post: 30th Jul 2011, 11:46 -
60fps versus 50fps? PAL or NTSC in AVCHD?? need advice!
By ftitus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th Nov 2010, 07:11 -
Converting a 720p .ts file from 50fps to 25 fps
By Bully9 in forum Video ConversionReplies: 14Last Post: 15th Sep 2009, 13:40 -
25fps to 50fps
By stavas in forum Video ConversionReplies: 8Last Post: 26th Sep 2008, 00:30
