I downloaded a movie and it's in a bunch of RAR files. Usually I just extract the first one and it's all good, but now when I try to extract ANY of them, it says that there are no files to extract, though there clearly is a bin and cue file in each folder.
has anyone else had this problem and how do i fix it
Results 1 to 11 of 11
obviously. i'm using winRAR and this is the problem i'm having
i even tried using winACE
also.. i've checked the sfv file in it and everything checks out ok -
This is a problem it tells you somthing is there when there isnt.I would say you didnt download the whole file,Or you friend doesnt know how to Rar Files/Video.
hmm this happened with the last movie i downloaded too, but everything prior was fine. think it's just bad luck?
You take your chances out there. That's why I wouldn't reccomend downloading from "friends".
Are there any PAR or PAR2 files? Also if it was created with recovery data you might be able to repair it.
Can you TEST the file to see if there are any errors?"The name on the front of your shirt is more important than the name on the back"
Kurt Russell - Miracle -
Sounds to me like an non-complete download or some type of corruption has occurred.
I've seen, and expirenced many zip, rar, tarball etc files that showed all the files, and even sometimes showed the correct archive file size, but the actual download was incomplete or corrupted.
Try re-aquiring the file from your friend(s) and if it occurs again, try a different method of transfer (if its mucking up over Yahoo, try irc, ftp etc).
Sabrowww.sabronet.com - It's all you need...to know
extracting .flac files with WINRAR
By burgkev in forum Newbie / General discussionsReplies: 9Last Post: 20th Apr 2010, 17:39 -
winrar problem
By catonic2206 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 11:27 -
problems with winrar
By kennyjunior in forum Video ConversionReplies: 1Last Post: 19th Nov 2007, 12:00 -
Splitting with winrar?
By chronic777 in forum Off topicReplies: 0Last Post: 17th Aug 2007, 07:17 -
Winrar error
By alintatoc in forum Newbie / General discussionsReplies: 17Last Post: 28th Jul 2007, 06:04
