I ripped one of my dvd's with smartripper
Worked well, played properly in Powerdvd
Used DVDSanta to shrink and burn
Video and audio very jerky
Any suggestions as to better method of shrinking and burning files ripped by Smartripper to a single 4.7g dvd-r.
Or better method of ripping and burning.
Am Interested in preserving as much quality as possible.
Results 1 to 10 of 10
snappy_carp
You can try DVDShrink. I use it all of the time as do most of the others at this site. Give it a try. If you are thinking of shrinking more than 20-30% you can expect some quality loss, regardless of the path you take. That is if you stick to the one disk backup philosophy.
Give DVDShrink a try, its free. What can be better. -
DVD Shrink to decrypt, encode, re-author and shrink and DVD Decrypter to burn to an ISO image, extremely user friendly.
Both applications are FREE and BRILLIANT. -
Thank you gents for all your posts.
Tried DvD shrink as per your suggestions, extremely easy to follow and Dvd turnd out perfectly
TYVM
:D
join full dvd's 2 or more & burn them in one dvd
By vampelle in forum DVD RippingReplies: 2Last Post: 2nd Oct 2010, 04:52 -
Full HD camera, burn on HD on DVD, etc?
By godwentpunk in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 51Last Post: 10th Sep 2009, 18:28 -
i have a 4 year old dvd burner that seams to burn a full dvd but the movie
By dr.bling in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Aug 2009, 22:20 -
extracting 2 dvd contents to burn to single DVD
By perfection in forum Authoring (DVD)Replies: 1Last Post: 18th Jul 2009, 09:26
