I ripped ogg files off of an audio 5.1 dvd.
Now how can i put them back on toa dvd so that i can keep the 5.1 sound?
I converted them into nero digital so i can burn them in that format, but is that a common/usuable format that allows 5.1?
I looked through nero audio options and other than digital i have wmv and mp3 cd, nothing seems to be of use.
If nero does not contain any programs that will let me do this what can?
Thanks Robb
p.s. does ogg keep the 5.1? what other formats can?
Look at Besweet http://dspguru.doom9.org/
I don't know much about OGG format, but it looks like Besweet has support for it. -
ogg vorbis supports upto 99 channels or so I think. Not sure about flac or speex. Channel coupling only works for 2 channels though.
Ripped ogg from an audio DVD? You mean you converted the audio from a DVD to ogg vorbis? If so how, because if you downmixed then the 5.1 is gone.
Yep, BeSweet supports ogg vorbis and AC3 encoding. ffmpeg should also work. Best thing would be just to grab the audio from the DVD again though.
OGG to AAC?
By Kid Boruto in forum AudioReplies: 6Last Post: 2nd Mar 2011, 07:45 -
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 19:28 -
How do I ogg to MKV
By SignedupGuest in forum Newbie / General discussionsReplies: 9Last Post: 13th Sep 2009, 22:56 -
ogg codec
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 21:22 -
Ogg to Ac3?
By t_jay17 in forum AudioReplies: 3Last Post: 13th Jun 2007, 10:55
