Hello all,
I was wondering how I would go about creating a dvd with alternate sound tracks. Specifically, I've got the NCAA championship game from my TIVO on my hard drive now, as well as the play by play from the local radio announcer. I'd like to make a dvd with the game as it appeared and sounded on tv, but with the ability to listen to the radio call if you want to. Any tips? Thanks.
Ed
GO HEELS!
Sometimes the light at the end of the tunnel is a train.
I believe you'll need to use something like DVD Studio Pro to author a DVD with more than one soundtrack. I don't think you can do it with iDVD or Toast.
yup!
You'd put the video on Video Track 1,
then put the audio on tracks 1 and 2 respectively.
( both must be in the same format type, ether AIFF or AC3)
Then create a Story that plays the Video and the normal track, then a story that plays the video and the Radio track.
Set a button for each STORY, and you got it.
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks for the suggestions, guys. I'll give it a try.
EdSometimes the light at the end of the tunnel is a train.
dvd to mkv but allow multiple sound/subtitle tracks
By chris789 in forum DVD RippingReplies: 6Last Post: 7th Feb 2012, 12:03 -
Authoring with more than 8 tracks of Audio
By RefresherEllie in forum Authoring (DVD)Replies: 9Last Post: 3rd Sep 2010, 00:33 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 23:17 -
authoring DVD with 2 audio tracks and soft subtitles
By Agent1266 in forum ffmpegX general discussionReplies: 6Last Post: 2nd Oct 2008, 16:34 -
How to remove sound tracks from a DVD?
By htp367 in forum EditingReplies: 5Last Post: 11th Oct 2007, 22:51
