    Dec 2001
    Germany
    Hi @ll,
    I have following problem. I have this movie, which is a pretty good quality as a divix-Avi. Now I tried to rip the *avi in 2 parts using VirtualDub - did only work for the first part. The second part would not work on the audio.
    So I decided to demux this movie and had a fine sound file. Then I used TMPGEnc to put the pieces together again and had some synch-Problem, which I solved by cutting out 2sec. of the original *avi. Now having a fine copy (w/ perfect synch) in *mpg. Still I need to get it on 2 CD - so I tried to cut it apart using TMPG again (and meanwhile) also a bunch of different cutting tools). Trying to do this I got again a perfectly working first part (now in *mpg) and a second one seeming to have the right ingredients (means video& audio). But when I try to open that file with any program - the programm doesn`t open it and even crashes.
    Any ideas? - I am close to throw this f***cking movie out of the window!!
    Greetinx from Berlin...
  2. Encode the whole movie to mpg with tmp. Then use Myflix and cut the mpg into two parts.
    Feb 2001
    Palmdale, CA
    As a last resort, you could use vdub to cut the avi into 2 parts, or since you got the first part to work, cut out the second part with vdub and encode with tmpenc, when I have a big divx I usually cut it with vdub, strip the audio, then encode the parts seperatly, then I avoid the sync probs with tmpenc, but as I have stated here before, you must have a perfect divx to start with, no video dropouts, if you do you will always have sound problems.
