Hello, i looked on the other topics and couldnt find my answer. I can open and run this file normally using Windows Media Player. Anyways I open my file in vitual dub and check the file information, it says 2 channels but the compression says unknown (tag 0055). I click on full processing mode and on compression i leave as No compression, I also change conversion to 41000. When i click on save .wav it says
No audio decompressor could be found to decompress the source audio format
I even have the AC3ACM codec installed. I even tried changing compression to MP3 or MPEG 3 but it still doesnt work. I dont know why it does this, please help. If this helps the file is
the.simple.life.s03e04.mortuary.pdtv.xvid-FQM.[BT]
maybe its the FQM is another codec i need?
My ultimate goal is to convert this as a VCD using TMPEG but i need to convert the audio since TMPEG wont recognize the audio as well.
Thank you.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Cobra
Closed Thread
Warez did you get that file from ? Open it up with GSPOT and it will tell you the audio codec.
Yes I opened it up with GSPOT and it says I already have the supported codecs installed. Also the codec is just a regular one that i normally use to play all my other video files [0x0055(MP3) ID'd as MPEG-1 Layer 3] for the audio codec.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Mp4, Aac & Wav Extraction
By mahendras in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 08:27 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
