I used to have a Panny DMR-E50 that I used to record shows/episodes.I would then use TMPGEnc DVD Author to cut out the commercials and make the menu.I left Hybrid VBR resolution on automatic on the E50 since I didn't really know what it did.I pretty much strictly use the LP 4 hour mode because I am putting a few TV Episodes on one disk.Well,I ditched the E50 and picked up the DMR-ES10.Since VBR is fixed and I am still using the 4 hour mode.Now TMPG DVD author says the video resolution 704 x 480 is not compatible with the current track which is at 352 x 480 which was recorded with the E50.I am trying to edit in 2 episodes that I recorded with the ES10 onto a DVD that already has a few shows that was done on the E50 I had.Is there any program I can use or way to get these 2 episodes that I created with the ES10 onto the disk I had already started with the E50 that has a few tracks on it?.Any help would be greatly appreciated.Thanks
***********************PROBLEM SOLVED***********************
