Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. What is best for Long term storage DVD-R or DV+R! Also would the answer be the same when using different speeds and/or Dual/double layer. Is there any diference between Dual & double layer or are the just different terms?
    TIA
  2. Member ice-berg's Avatar
    Oct 2003
    Cold as Ice
    Being a DVD-R or DVD+R does not have any bearing, same goes to the writing speeds.
    The quality of the media you use will be the factor that determines if the media will last in the long run (given that youre using a descent burner also).
    Dual layer and double layer mean the same.
  3. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    I only have one word here:
    Finalize (your discs)
  4. Originally Posted by dcsos
    why?
  5. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    FINALIZING will prevent others from erasing the "LONG TERM DATA" we
    are trying to preserve here ......(inadvertently or maliciously speaking)
