I used RC7 no real problems but used RC8 for first time & get this error.
Version:SVCD2DVD 2.0 RC8
Type: System.ArgumentException
Source: System.Drawing
Message: Invalid parameter used.
InnerException:
StackTrace: at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
at System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
at System.Drawing.Icon.ToBitmap()
at System.Windows.Forms.ThreadExceptionDialog..ctor(E xception t)
at System.Windows.Forms.ThreadContext.OnThreadExcepti on(Exception t)
at System.Windows.Forms.Control.WndProcException(Exce ption e)
at System.Windows.Forms.ControlNativeWindow.OnThreadE xception(Exception e)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchM essageW(MSG& msg)
at System.Windows.Forms.ComponentManager.System.Windo ws.Forms.UnsafeNativeMethods+IMsoComponentManager. FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
Any Ideas ?
Thx
In the first instance can you try reinstalling? If you still get this, please let me know & I'll try some diagnostics with you offline.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error Message?
By mikehr in forum ffmpegX general discussionReplies: 2Last Post: 8th Oct 2007, 01:22 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 21:13
