How reliable are Ritek G05 (8X) Inkjet White DVD-R (Hub Printable) Discs??
I need to know before I purchase or someone recommend a good brand that is affordable & any site recommendations would be appreciated as well. thanks
Results 1 to 14 of 14
Father knows best.
Have burned & printed over 250 Ritek G05's, using my nec2500a & epson r300. No problem's. In the UK I buy them here http://www.rambox.co.uk/index.php
I have bought these with no issues on my Pioneer 109
http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=1782-1...tegory_Code=GP -
My Pioneer 106 has had NO problems with them
My BTC (your IOmagic) burns are terrible at 8x but burns good at 4x -
Bought 25 of these branded as 'Traxdata'. All burned perfect on a AOpen DUW1608/ARR at 8x with no coasters. A word of warning for speed freaks, although the maximum record speed was indeed 8x the average was nearer 5.6x as took a while for the burn process to reach maximum. Would buy again but for having an unhappy experience with the dealer over a diferent matter.
Thanks all, I ordered some, I will post back my results.
Father knows best. -
G04 were good. The old G05 were ok, but the new G05's are not nearly as good. If they work for you, great. The price is good now.
The batch of G05 -R 8x white I got from SuperMediaStore on April 1 will not work in my Sony DRU510a. Never had a problem before now. I have 87 blanks and 11 coasters, anyone interested???
I bought some Prodiscs from Supermedia store. I had to send them all back.
But on a lighter note, The Ridata's I got from am-dig.com are working out fine for me.Father knows best. -
I've used ritek go5 inkjet printables and I've used prodisc,linkyo and name brands....I burn dvd's everyday...sell them and as for quality...I use a nec nd-3500 and never had a problem with the ritek G05 not to mention that the video is clearest with the ritek G05...I use krylon clear gloss spray....I put the dvd in a dvd case...I use a dryer sheet....I spray a small amount on the dryer sheet and apply from the center in a circular motion going outward slow and soft...not hard so I dont screw up the print....the ink will smudge if you do it hard....never had a problem!!!! It's kinda like waxing a car...one full circle the the next full circle allthe way to the end...be careful not to get the gloss on the recorded surface because it will cause a read error that can't be corrected!!!
Is what we learn indeed a fact, or someones opinon? -
Originally Posted by martin474
http://www.ritek.com/products/dl/DVD_minus_%20PC_Burner_compatibility_04_25_2005.pdf -
retek go5 dye in any form was crap,the only ones to buy are the "extreme" range,and even there shit.
best avoid G05 dye,as ridata have even acknowledged this,and use prodisc,and cmc dyes in there discs.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
JVC Taiyo Yuden Blu-ray White Inkjet Printable 4X 25GB BD-R LTH
By xobituaryx in forum MediaReplies: 2Last Post: 17th Jan 2011, 09:25 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 05:31 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 08:06 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 10:29 -
Ritek CD-R White Printable Quality
By mmbetz in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2007, 20:32
