I am having a problem converting a PAL video tape to progressive. It should be a piece of cake, but the field order keeps changing. Anybody have any experience with this?
Darryl
Results 1 to 14 of 14
That needs a TBC
(and better drivers than pinacle ones...)La Linea by Osvaldo Cavandoli
TBC also locks the field order (from what I know)
What are you using for capture?La Linea by Osvaldo Cavandoli
I had this problem a couple of years ago , I used a filter in VirtualDub to sort it out - "Dynamic Field Order Correction" by Shaun Faulds
http://www.hlinke.de/Vdub-Filterlist/vdub-filterlist.html
Direct Link to download it .
http://www.hlinke.de/DFOC-v1.0.zip
Its cheaper than a tbc if it works . -
OK, here is my report after trying out the Dynamic Field Order Correction filter. The filter did not fix the problem. But I found it useful nonetheless.
That being said, I did find my solution. Changing from PAL_B to PAL_H within my capture device settings completely solved my problem. Now if I only knew why...
Darryl -
PAL H? I never heard off! Or you mean PAL N/M ?
Hmmm.... Maybe your VCR output NTSC50?La Linea by Osvaldo Cavandoli
quote:Originally Posted by SatStorm
Pal-B, G, H, I and D as far as the actual video is concerned, are all the same format. That is: they are all PAL. There is no difference. All use the 625/50 line/field rate..... scan at 15,625 h-lines/sec and use a 4.433618 color subcarrier frequency. The only difference is in how the signal is modulated for broadcast. Thus the B, G, H, I & D designate broadcast variations as opposed to any variation of the video format. PAL-I for example, has been allocated a wider bandwidth than PAL-B, necessitating that the sound carrier is placed 6Mhz above the picture instead of 5.5 MHz above the picture carrier. Thus a PAL-I TV (the United Kingdom for example) will get no sound if taken to the Netherlands for example (PAL-B) if all the TV's tuner is able to decode is PAL-I. (Fortunately, most European tuners support most of the broadcast variations ).
This is why for example, you won't find a standards converter that will convert a video from PAL-B to PAL-I. There's simply nothing to convert.....They are already the same PAL format. There are major differences between PAL-M and PAL-N however, that would require conversion, as the line/field rate and color subcarrier frequencies are different from standard PAL.
:unquoteI think,therefore i am a hamster. -
Thanks...
I know about PAL B/G/D/I and also PAL-M (Brazil) and PAL - N (Argentina).
I never heard of PAL H though. Which country actually use this?La Linea by Osvaldo Cavandoli
http://www.videoequipment.com/access/formats.html
For fuller table see above , but its apparently Belgium , Gibraltar , Liberia and Malta . -
Oh, yeah! Right! It's a broadcast variation for UHF frequencies!
Thanks againLa Linea by Osvaldo Cavandoli
I don't understand it, but I am glad it worked. MY first capture was using PAL_B and I was getting progressive mixed with interlaced. Upon close inspection, some frames repeated, some frames dropped, some fields were dropped, and some fields were out of order. This was revealed by doing a bob-deinterlace and inspecting the video frames. I was completely unsure how to handle this video to restore it to progressive. According to the capture software, no frames were dropped.
Changing it to PAL_H and recapturing solved it completely. The missing frames were back, the repeating frames were gone, and the out of order fields were in the correct order. I don't know why, but PAL_H fixed it. I am not sure where my tape is from, but I didn't think it was Belgium, Gibraltar, Liberia, or Malta.
Darryl -
It's a mistery of life my friend!
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 08:58 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 07:06 -
Field order for PAL DVD
By PeskyJ in forum Authoring (DVD)Replies: 3Last Post: 29th Dec 2008, 21:59 -
Swapping field order in progressive video.
By jmail524 in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 13:53 -
Changing field order flags = losing chapter points.
By gadgetguy in forum Authoring (DVD)Replies: 2Last Post: 5th Jan 2008, 13:13
