Hi all -
I am trying to create a 'Best Of' disk with scenes from my favorite movies.
Here is my current process:
Using DVD Shrink re-author mode, rip the scenes to seperate folders.
Using DVD Shrink again in re-author mode, open all the seperate hard-drive movies and compile my best-of DVD and burn to disk.
My problem is this - I need to import the titles into DVD shrink seperately, and when the disk burns, each imported title burns seperately. When this plays back on my set-top DVD player, there is about a 1 second pause for each title switch.
What I would like is the final compilation DVD to have only one title, ideally with a chapter break at the beginning of each scene.
Can anyone recommend a better method for doing this, or a guide that tells how this is done?
Thanks.
E
If you really want one title you will have to demux the audio and video, join it together, then re-encode and re-author with your chapter stops. Thissame problem came yesterday with another poster who had cut the commercials from a TV episode and left the bits a seperate titles in the hope it would create chapter stops. Unless you hide it with a fade in / fade out, you will get the pauses.
Read my blog here.
Ok. Thanks.
I was hoping there was a way to do this without demuxing/re-encoding/etc.
E
Video Compilation
By redcapeman in forum EditingReplies: 4Last Post: 27th Dec 2010, 05:01 -
Weird Compilation Errors
By theWallflower in forum Authoring (DVD)Replies: 8Last Post: 8th Apr 2010, 07:00 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
When Ripping Compilation CD's...
By Nitro89 in forum Off topicReplies: 3Last Post: 1st Nov 2009, 08:48 -
DVD compilation.
By Benhermies in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2008, 11:46
