I've got a few questions about the settings in TMPG 3.0 Express.
I'm converting AVI files recorded through a Avermedia PCI card. (These are S-VHS videos.) These are going to be watched on a standalone DVD player through a 'regular' interlaced TV.
In the 'Filters-Deinterlace' section, it automatically selects 'DeInterlace only when necessary'. If I select 'Keep-interlaced', I get all sorts of dire warnings.
Since interlaced VHS video should never normally be de-interlaced, is it best to ignore these warnings and always use the 'Keep Interlaced' setting?
Second, in the output section it automatically sets a finished file size of 4200 MB. When I used that as a default and authored with TMPG DVD Author 1.6, the finished DVD only used about 95% capacity of the disc. (I'm only making relatively simple menus in authoring, no motion menus, etc.)
When I encoded my last project, I set the output file size in TMPG 3.0 Express to over 4300 MB, 104% of capacity. I still ended up with a final DVD about 1% short of full capacity.
5% is too much to lose (1% is too little to worry about, I suppose) but it seems odd that I should always have to set the capacity to over 100%.
What should I set the minimum bitrate to, while encoding? It defaults to zero. Should it be padded or ??
Lastly, I have read another thread on this forum about changing the max. bitrate to 9800 (from the normal max of 9200), by going into the 'Advanced MPEG' settings and making a slightly out of spec DVD. I tried this once and the resulting DVD did play fine, but has anybody else tried this? Does it even make a difference?
Thanks for any help you can give me.
Results 1 to 1 of 1
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 20:20 -
Express
By webmaster P in forum DVD RippingReplies: 0Last Post: 20th Jan 2009, 21:27 -
Best settings voor TMPG Express MTS Files to Divx Avi
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Mar 2008, 09:36 -
Outlook Express
By snuggels in forum ComputerReplies: 4Last Post: 12th Jul 2007, 18:40
