    Feb 2001
    Hey, I've got a problem, that I've never had before. Tmpegenc has always worked perfectly, until now. I recently bought a concert on DVD, Dream Theater - Metropolis pt 2 (great concert and I want to convert it to VCD.
    I've done this many times before, both to VCD and SVCD.
    Well the problem is that after ~35-40 minutes into the VCD file (which looks great apart from that) the audio becomes out of sync. Since it's a concert, you notice it very clearly (cymbal crashes etc!)
    The specs I can give:
    Source: PAL DVD
    Programs used: CladMdec, DVD2AVI and Tmpegenc.
    (I don't think my computer specs are important here, are they?)
    The only settings I've made in Tmpeg is that I loaded the VCD template (PAL) and then I chose deinterlace as a filter, and chose motion search highest quality.
    Hmm is there anything I could've done wrong?
  2. hrm..since the audio is not outta sync by the same length throughout the rip...
    perhaps it's a framerate problem....maybe you're losing frames and that's wut's causing your rip to be slowly outta sync...
    Feb 2001
    Well it's probably out of sync all the way, but only enought to notice after 35 minutes?
    /Johan
  4. Hi,
    If you want to solve the Sync Problem just use this great software ACID PRO 3.0 from Sonic Foundry.You can download the Demo Version from their site.
    Bye.
  5. well...if the audio is outta sync for exactly the same time length for the entire movie..u can fix it during the actual encode...
    in tmpgenc, there is a source range filter..under it..there is an audio skew option where u can tell tmpgenc to add the audio milliseconds before or after the video so u can get your audio 'N Sync..
