Hi,
Whenever I have an ntsc dvd, I use dvd2svcd to convert it to pal (my tv doesnt support ntsc)
The only problem with using dvd2svcd is that it only converts the movie, and not menu's, extras etc
Is their anyway that I can convert the whole dvd, or anyway of doing it in pieces...I.E Ripping and converting the menu, then converting the extras, then the main movie and then joining them all together?
Many thanks peeps
I don't know of an easy way to do it. There are a number of issues, including framerate and resolution, that can affect the time of menus and the position of subpictures that would make it difficult. Check the guides (to your left) to see if anything stands out.
Read my blog here.
Pal To NTSC Menu Conversion
By Mastiland in forum Newbie / General discussionsReplies: 10Last Post: 7th Dec 2010, 13:14 -
Help. Convert menu sublayer from 720x576 to 720x480 (PAL to NTSC)
By danfisherman in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 11:56 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 11:46 -
NTSC assets for a PAL standard menu
By barnsleyboy in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 4th Sep 2007, 08:54 -
PAL to NTSC, Menu, Chapters
By heretic754 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2007, 13:46
