Ok, so I want to use the bitrate calculator found @
http://www.vcdhelp.com/calc.htm
The first thing the calculator wants to know is Video Min & Secs.
I have my video file in 6 segments and was wondering if there was a piece of freeware that would take the files I threw at it and tell me the video time length. Anything available?
Thanks,
Troy
My suggestion to you, is that you take your head and thrust it forward onto a marble slab.
eheh
Troy
I will think about it.
Seriously I do not see a problem. Play the segments with media player and calculate. Or use Avisynth, load all segments and play the .avs with media player.
Yeah I figured I could do the old lead and paper method, but just wondering if there was a tool, since I have 30 TV shows to rip and burn...
Thanks,
Troy
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
AVI playback shows frame rate and time code etc
By piledriver351 in forum Software PlayingReplies: 5Last Post: 26th Aug 2008, 03:42 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
How total data rate is calculated?
By Netozai in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 16:47 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 22:55
