Would sure appreciate some help. I have tired this over and over again and failed, I searched for similar topics and found a few but missing some info I need as a newbie. Can someone please help me through the steps of using "join" in ffmpegX to combine 2 AVI files. I have a movie
in 2 parts and would like to join as one and write to a DVD. I'm soooo
confused. Do I start with both files as AVI's? or first encode each individually? If I encode them what setting should I use?
Also, do I add one file to the "Summary" Source format and then
the 2nd through browse under "Tools"? I am so lost here. It's probably
so simple, but I just don't get it! I'm ready to pull my hair out
If anyone could walk me though the steps I would be very grateful as I'm ready to give up! (it probably doesn't make a difference, but I'm on
a Macintosh). Thanks so much!
Appreciated your reply and was eager to try. Seemed so easy until I downloaded "Sizzle" from Version Tracker. Could not get anything in the program to work. It's like a "dead" copy.
No windows, nothing to open, just a menu at the top that offers no working options. Are there some codes that I am missing here? I assumed that everything you need is downloaded with the program but now I'm thinking that's not the case. Tried downloading 3 times, same thing happens. Any thoughts on what I'm doing wrong?
You need to install Arial and or Arial black (fonts) to get Sizzle to display properly, if I remember correctly.
Another option would be to use MPEG Streamclip to join your MPGs and then author a video_ts in FFMPEGX from the joined MPEG
Alph
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 04:42 -
can I join multiple avi files?
By afteryouwho in forum ffmpegX general discussionReplies: 5Last Post: 20th Dec 2009, 06:56 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 13:49 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 23:56 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
