well.. it's not actually 2 movies. I downloaded one movie and it came as two seperate .avi files, part 1 and part 2. i converted them both to dvd and want to burn them. the problem is that part one and part two are located in two seperate folders and the files in each have the same name. when i select part 1 and then part 2 to burn it asks if i wish to overwrite the the first file since part 2 has the same file names. if i try to change the names of the files they wont burn.
how can i do this
You need either tmmgenc DVD author or DVD Lab Pro. Either of these can load up the vob files and allow you to link them in order. If you want more info, try doing a search or reading some guides.
Read my blog here.
Burning Movies onto Dual Layer disc
By josevargas in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2010, 20:43 -
New DVD to hold 2000 movies on 1 disc
By Rudyard in forum Latest Video NewsReplies: 41Last Post: 8th Nov 2009, 06:10 -
write 2 movies in 1 disc
By akakiami in forum DVD RippingReplies: 6Last Post: 10th Sep 2008, 07:06 -
after buring DL+R disc, my burn can't burn -R disc, please help!
By princejoe18 in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Sep 2007, 07:44 -
Two movies on a 4.7MB disc??
By Noy2014 in forum Authoring (DVD)Replies: 5Last Post: 15th Aug 2007, 11:08
