I have 3 movies I want to put on a DVD. I have everything set up and it looks great. But I want some music(maybe 30-60seconds worth) to play/loop when it is on the main menu. I don't know how to do this. Can someone help?
Results 1 to 14 of 14
AFAIK the only way to do this in TMPGEnc DVD Author is to make a motion menu. To do this you need to create a DVD-compliant MPEG of your background image muxed with your music. TMPGEnc Plus can take JPGs as the video source.
If in doubt, Google it. -
...and I think I've seen that not all DVD compliant audio formats work for menus (in TDA). Can't remember which doesn't work, but I wouldn't be surprised if it was AC3.
/Mats -
If my memory serves me right, I think it has to be either WAV or MP2 only. Possibly even MP2 only.Originally Posted by mats.hogbergThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
- I was under the impression that the AC3 plugin was only needed if you used TDA to encode to AC3?
/Mats -
If jimmalenko's memory serves mats correctly, then I think you're right...Originally Posted by mats.hogberg
Carpe diem.
Well, if my memory serve's you correctly, then I believe that matsloaf once said "Three out of four ain't bad", or was it "Two out of three..."?Originally Posted by jimmalenkoThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
"I want you", "I need you", "But there ain't no way I'm ever gonna love you" Hmmm... I'd say "two out of three".
/Mats -
And what audio formats are acceptable from WAV, MP2 or AC3?Originally Posted by northcat_8There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Question how to add subtitles with TMPGEnc DVD Author 3
By jimdagys in forum SubtitleReplies: 1Last Post: 5th May 2008, 18:24 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
